VPEX.AutoConfig.InitTrunkCflct
Description
On initial discovery of a BPE on a port, VPEX Auto-Configuration uses the port to form a cascade port trunk, provided the new port is not already part of a Trunk.
Remedy
This event may occur after moving cables or using CLI commands to modify configuration while VPEX Auto-Configuration is running, or by cabling BPE's together in an unsupported pattern. Use "show log" to look for errors or warnings, and "show config vpex" to see configuration elements added by VPEX Auto-Configuration and other configuration agents.
Severity
Warning
Message Text
Port %port% is already part of a trunk and cannot be reconfigured as a new cascade port trunk.
Message Parameters
Name Type
port SlotPort
